hjälp med värmen i kupen
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
hej har en kuga 2011 då jag ställer den på lägsta tem så blåser det kallt..men så fort jag ställer upp den ett steg så kommer värmen...för mycket för ett steg 17 grader...tipps på vad det kan vara----
Micke53 skrev:hej har en kuga 2011 då jag ställer den på lägsta tem så blåser det kallt..men så fort jag ställer upp den ett steg så kommer värmen...för mycket för ett steg 17 grader...tipps på vad det kan vara----
Du kan göra ett självtest av den och se om det dyker upp några felkoder. :)
The climate control and heating system features a on-board diagnosis function which can detect and store both current permanent faults as well as intermittent faults which have occurred during normal operation of the vehicle. It is also possible to read out these faults via the display on the
control panel of the climate control system. To read out the fault memory, the ignition key must be turned to the "ON" position and the battery voltage
must be between 9 V and 16 V.
To activate the on-board diagnosis at the control panel for the climate control system, PRESS the "OFF" and "FOOTWELL" buttons simultaneously
for exactly 2 seconds, then PRESS "AUTO" within 1.5 seconds. The on-board diagnosis which then starts lasts a few seconds. An animated display
appears in the display of the control panel for the climate control system during this time. Any faults found are displayed on both displays of the control
panel for the climate control system in the form of trouble codes.
To read out saved errors at the control panel for the climate control system, PRESS the "OFF" and "FOOTWELL" buttons simultaneously for exactly
2 seconds, then PRESS "HEAD AREA" within 1.5 seconds. Any stored faults are shown on the display of the control panel for the climate control
system and should be noted for safety reasons.
By PRESSING the "DEFROST" button, the fault memory is cleared and diagnosis mode is ended.
To end the diagnostic mode without clearing the DTCs, PRESS any other operating button on the control panel for the climate control system.
To read out the software version at the control panel for the climate control system, PRESS the "OFF" and "FOOTWELL" buttons simultaneously
for exactly 2 seconds, then PRESS "A/C" within 1.5 seconds. The software version is shown on the display of the control panel for the climate control
system. The output mode can be exited by PRESSING any button on
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
Det står 92 och 51...vad menas med det
Micke53 skrev:Det står 92 och 51...vad menas med det
Det betyder DTC-felkod B9251 som i sin tur betyder "In-vehicle temperature sensor open circuit" (om jag tittar på rätt ställe).
Givaren sitter på höger sida om ratten nere vid stereon, den borde gå att mäta upp för att se om den är hel. :)
Ser ut som om det bara är att lossa knappsatsen (bara att trycka in spärren på baksidan) till stereon vid ratten och lossa plastkåporna (den övre lossas i framkant och den undre sitter med en skruv) runt ratten för att kunna komma åt givaren. :)
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
Tack för snabbt svar
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
var hittar man beskrivning hur man gör?
Micke53 skrev:var hittar man beskrivning hur man gör?
Du har PM. :)
Passa på att ta kort och lägg upp här sedan när du har skruvat lite. :)
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
Tack...ska göra det
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
Glömde ta kort men beskrivningen funkade klockrent...tog 15 min att göra det
Micke53 skrev:Glömde ta kort men beskrivningen funkade klockrent...tog 15 min att göra det
Alla tiders, hittade du några fel? :)
Micke53
Namn: Micael Moberg
Kör: Ford Kuga
Inlägg av Micke53 »
Jo det var sensorn i kupén....den som sköter om värmen.
Christian74
Namn: Christian Eksten
Kör: Ford Focus
Inlägg av Christian74 »
Min Ford Focus 2010 aircondition beter sig exakt som Micke53 bil. Har gjort en självtest vilket gav samma felkoder (52 91) som Micke53. Jag har nu beställt en ny sensor. Undrar om någon vänlig själ kan försöka förklara för mig hur jag skall hitta den i kupén och byta den. Jag är ju tvärr inte den händigaste så att säga. Kanske borde jag posta i nytt ämne och isf får ni gärna flytta på denna fråga. Tack på förhand.
Christian74 skrev:Hej!
Hittade en video, ser hyffsat lätt ut att byta iallafall. :)
Christian74
Kör: Ford Focus
Den funkar perfekt nu. Haft strul med AC hur länge som helst. Fick kostnadsförslag att byta AC eller en del av den för 2000kr + jobb och att det var felet med 99% säkerhet. Glad att jag av en slump hittade en video där man kunde göra en felsökning. Fick fram felkoder och hittade hit :)
Tack Rickard och Micke53
Christian74 skrev:Den funkar perfekt nu. Haft strul med AC hur länge som helst. Fick kostnadsförslag att byta AC eller en del av den för 2000kr + jobb och att det var felet med 99% säkerhet. Glad att jag av en slump hittade en video där man kunde göra en felsökning. Fick fram felkoder och hittade hit :)
Alla tiders! Bra att det löste sig. :)
