Cosworth Komplett Bromskit 330mm / 356mm (Fram)
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Ford Komplett Bromskit 330 356 380mm Fram / Bak
Ksport ProComp Big Brake Kit
KS Big Brake kits provide the ultimate in stopping power for your vehicle.
Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking.
These brake systems are designed for easy installation with minimal tools required.
The KS Big Brake kit includes:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
KS SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194°F - 1022°F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads. The average coefficient of friction on this pad is between .46 and .53.
Bromsar FRAM finns för närvarande till följande bilmodeller:
Ford Escort Cosworth 4x4
Ford Sierra Cosworth 4x4
Ford Escort 90-00
Ford Probe V6 93-99
Ford Focus 04+
Ford Focus SVT 02-04
Bromsar BAK finns för närvarande till följande bilmodeller:
Ford Focus 04+
Ford Probe V6
Går även utmärkt att använda bromsbelägg från bl.a följande tillverkare:
AP RACING, FERODO, MINTEX, EBC, PAGID, CARBON METALLIC, HAWK mfl.
För ytterligare information samt komplett modellutbud vänligen se vår hemsida http://www.raidopower.se
Pris, komplett kit inkl bromsskivor, 8/12-kolvs alu-bromsok, stålomspunna bromsslangar, bromsbelägg samt monteringsdetaljer, just nu endast:
12.995 SEK inkl moms (330mm, FRAM 8-kolvs bromsok)
15.995 SEK inkl moms (356mm, FRAM 8-kolvs bromsok)
23.995 SEK inkl moms (380mm, FRAM, 12-kolvs bromsok)
12.995 SEK inkl moms (330mm, BAK 6-kolvs bromsok)
15.995 SEK inkl moms (356mm, BAK 6-kolvs bromsok)
Leveranstid:
Ca 1-2v efter att beställning/betalning inkommit till oss.
Beställning:
Görs direkt via vår webbutik, http://www.raidopower.se
Betalning:
Kreditkort, Bankgiro.
För aktiebolag erbjuder vi köp mot faktura.
Räntefri avbetalning via Wasa Kredit.
Frågor etc hänvisas till PM alternativt E-post sales(a)raidopower.com
Mvh
Raidopower.com
- * 6, 8 or 12 Piston Lightweight Aluminum calipers
* High quality brake pads
* D.O.T. Compliant Stainless steel brake lines
* Machined aluminum hats
* Carbon steel brackets
* 330mm (13"), 356mm (14") or 380mm (15") large ventilated discs (17"/18"/19" wheels required)
* KS SC5 street brake pads
KS SC5 Street Pads:
Ford Escort 90-00
Ford Probe V6 93-99
Ford Focus 04+
Ford Focus 04+
Ford Probe V6
Leveranstid:
Beställning:
Betalning:
Mvh
Raidopower.com
Styling - Tuning - Multimedia
cosworth511
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Emil, de står ej listade till RWD, och det finns ju vissa skillnader mellan RWD/4x4, så det är inget vi kan garantera.cosworth511 skrev:går det å bygga om från 4x4 sierran till rwd sierran ??? om det är nån som vet??
mvh emil
Vi har endast monterat det på Escort/Sierra Cosworth 4x4.
Finns förhoppningsvis någon här på forumet som sitter inne med ett definitivt svar.
Mvh
Raidopower.com
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Hej Jocke,stampe skrev:Ni kan inte ordna till en mondeo st200....Mvh Jocke
Finns i dagsläget till följande fordmodeller:
Bromsar - FRAM
Bilmodell Årsmodell Bultmönster
Ford Focus 04-x (5x108)
Ford Focus SVT 02-04 (5x108)
Ford Probe V6 93-99 (5x114,3)
Ford Escort Cosworth 4x4 (4x108)
Ford Sierra Cosworth 4x4 (4x108)
Bromsar - BAK
Givetvis kan dessa kit passa på andra bilmodeller, med/utan modifikation, men det är inget som vi kan garantera.
Mvh
Raidopower.com
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
cosworth511
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Har du en Sierra Cosworth 4x4 eller Escort Cosworth 4x4 och är sugen på frambromsar?
Kontakta oss på sponsor@raidopower.com och bifoga spec på din bil samt bilder, vi erbjuder just nu reducerade priser (brgränsat antal).
Mvh
Raidopower.com
Mvh
Raidopower.com
