Ksport Coilovers - Flera modeller
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
KS PRO Coilover Kit
KS Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The KS system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The KS Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features Coilovers :
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
Finns för närvarande till följande bilmodeller:
Ford Tierra 92+
Ford Aztec 95-98
Ford Liata 95-98
Ford Probe 88-92
Ford Probe 93-99
Ford Telstar 93-97
Ford MAV 98+
Ford Focus 2WD DA3 04+
Ford Focus C-MAX 2WD 03+
Ford Mondeo 98+
Saluförs i 5st konfigurationer: Gata, Bana, Drifting, Rally, Stripp.
För ytterligare information samt komplett modellutbud vänligen se vår hemsida http://www.raidopower.se
Pris:
Just nu endast 7.495kr inkl moms (5.996kr exkl moms)
Leveranstid:
Ca 1-2v efter att beställning/betalning inkommit till oss.
Beställning:
Görs direkt via vår webbutik, http://www.raidopower.se
Betalning:
Kreditkort, Bankgiro.
För aktiebolag erbjuder vi köp mot faktura.
Räntefri avbetalning via Wasa Kredit.
Frågor etc hänvisas till PM alternativt E-post sales(a)raidopower.com
Mvh
Raidopower.com
Ford Tierra 92+
Ford Aztec 95-98
Ford Liata 95-98
Ford Probe 88-92
Ford Probe 93-99
Ford Telstar 93-97
Ford MAV 98+
Ford Mondeo 98+
Pris:
Leveranstid:
Beställning:
Betalning:
Mvh
Raidopower.com
Styling - Tuning - Multimedia
- Lill Raggarn
- Namn: Patrik Lindberg
- Kör: fram och tillbaka till jobbet i Diesel doris.......
- Lill Raggarn
Raidopower
- Namn: Andreas H
- Kör: Alla bilar.
Ksport erbjuder i dagsläget ej färdiga coiloverkit till Cosworth.
Patrik: Flera utav modellerna som Ksport erbjuder saluförs ej i sverige som nybilar, men med dagens importer från "hela världen" så har vi valt att presentera samtliga bilmodeller som Ksport erbjuder.
Mvh
Raidopower.com
Mvh
Raidopower.com
- Lill Raggarn
- Mullis
- Namn: Daniel Andersson
- Kör: Bil, kanske
De verkar vara en Fordmodell ifrån Taiwan. Tycker att den nya påminner om, faktiskt, Mondeo fast mindre...Lill Raggarn skrev:vad är ford tierra?
Hittar ingen gammal modellbild, bara nya...
MVH // Mullis
