airbag
Granworth
Namn: Kristian S
Kör: Transit oljebrännare , scorpio ghia 94 .
Dröm bil , se foto.
Medlemsnummer: 540
airbag
Inlägg av Granworth »
Tjena.
En god vän till mig köpte igår en fin scorpio 93 , 2,9 kombi ghia .
Problemet är airbag lampan .
när vi startar bilen så slocknar lampan , Men den tänds och lyser konstant efter ca 20-25 sekunder ??? ,
Någon som har tips på att åtgärda detta Eller vad som kan vara felet ??
kollade inför bess och det blir en 2 /återbess pga detta ..
Krille.
Old Fords Never Die They Just Goes Faster.. :racesmile
Re: airbag
Granworth skrev: ↑
lör okt 10, 2026 1:36 pm
Tjena.
Krille.
Om ni bara vrider på tändningen, blinkar lampan någon kod?
1.2 DTC B1231: Longitudinal acceleration threshold exceeded. Lamp flash code: 13
1.3 DTC B1317: Battery voltage high. Lamp flash code: continuous
1.4 DTC B1318: Battery voltage low. Lamp flash code: continuous
1.5 DTC B1342: Air bag control module is defective. Lamp flash code: 12
1.6 DTC B1869: Air bag warning indicator open circuit or short to ground. Lamp flash code: continuous
1.7 DTC B1870: Air bag warning indicator short to battery. Lamp flash code: continuous
1.8 DTC 1884: Passenger air bag deactivation indicator inoperative. Lamp flash code: 18
1.9 DTC B1890: Passenger air bag deactivation indicator short to battery. Lamp flash code: 18
1.10 DTC B1891: Air bag tone warning indicator short to battery. Lamp flash code: 53
1.11 DTC B1892: Air bag tone warning indicator circuit fault. Lamp flash code: 53
1.12 DTC B1921: Air bag diagnostic monitor ground circuit open. Lamp flash code: 14
1.13 DTC B2290 Error value 27: Occupant Classification System module fault. Lamp flash code: 16
1.14 DTC B2290 Error value 26: Occupant Classification System communications fault. Lamp flash code: 16
1.15 DTC B2290 Error value 25: Occupant Classification System calibration fault. Lamp flash code: 16
1.16 DTC B2290 Error value 24: Occupant Classification System sensing element fault. Lamp flash code: 16
1.17 DTC B2292 Error value 31: Driver safety belt pretensioner circuit low resistance. Lamp flash code: 33
1.18 DTC B2292 Error value 30: Driver safety belt pretensioner open circuit. Lamp flash code: 33
1.19 DTC B2292 Error value 29: Driver safety belt pretensioner short to battery. Lamp flash code: 33
1.20 DTC B2292 Error value 28: Driver safety belt pretensioner short to ground. Lamp flash code: 33
1.21 DTC B2292 Error value 27: Passenger safety belt pretensioner circuit low resistance. Lamp flash code: 34
1.22 DTC B2292 Error value 26: Passenger safety belt pretensioner open circuit. Lamp flash code: 34
1.23 DTC B2292 Error value 25: Passenger safety belt pretensioner short to battery. Lamp flash code: 34
1.24 DTC B2292 Error value 24: Passenger safety belt pretensioner short to ground. Lamp flash code: 34
1.25 DTC B2293 Error value 31: Driver air bag first stage short to ground. Lamp flash code: 19
1.26 DTC B2293 Error value 30: Driver air bag first stage short to battery. Lamp flash code: 19
1.27 DTC B2293 Error value 29: Driver air bag first stage open circuit. Lamp flash code: 19
1.28 DTC B2293 Error value 28: Driver air bag first stage circuit low resistance. Lamp flash code: 19
1.29 DTC B2293 Error value 27: Passenger air bag first stage short to ground. Lamp flash code: 21
1.30 DTC B2293 Error value 26: Passenger air bag first stage short to battery. Lamp flash code: 21
1.31 DTC B2293 Error value 25: Passenger air bag first stage open circuit. Lamp flash code: 21
1.32 DTC B2293 Error value 24: Passenger air bag first stage circuit low resistance. Lamp flash code: 21
1.33 DTC B2293 Error value 23: Driver air bag second stage short to ground. Lamp flash code: 19
1.34 DTC B2293 Error value 22: Driver air bag second stage short to battery. Lamp flash code: 19
1.35 DTC B2293 Error value 21: Driver air bag second stage open circuit. Lamp flash code: 19
1.36 DTC B2293 Error value 20: Driver air bag second stage circuit low resistance. Lamp flash code: 19
1.37 DTC B2293 Error value 19: Passenger air bag second stage short to ground. Lamp flash code: 21
1.38 DTC B2293 Error value 18: Passenger air bag second stage short to battery. Lamp flash code: 21
1.39 DTC B2293 Error value 17: Passenger air bag second stage open circuit. Lamp flash code: 21
1.40 DTC B2293 Error value 16: Passenger air bag second stage circuit low resistance. Lamp flash code: 21
1.41 DTC B2294 Error value 31: Driver side air curtain circuit short to battery. Lamp flash code: 24
1.42 DTC B2294 Error value 30: Driver side air curtain circuit short to ground. Lamp flash code: 24
1.43 DTC B2294 Error value 29: Driver side air curtain circuit open circuit. Lamp flash code: 24
1.44 DTC B2294 Error value 28: Driver side air curtain circuit low resistance on squib. Lamp flash code: 24
1.45 DTC B2294 Error value 27: Passenger side air curtain circuit short to battery. Lamp flash code: 25
1.46 DTC B2294 Error value 26: Passenger side air curtain circuit short to ground. Lamp flash code: 25
1.47 DTC B2294 Error value 25: Passenger side air curtain circuit open circuit. Lamp flash code: 25
1.48 DTC B2294 Error value 24: Passenger side air curtain circuit low resistance on squib. Lamp flash code: 25
1.49 DTC B2295 Error value 31: Driver side air bag circuit short to battery. Lamp flash code: 22
1.50 DTC B2295 Error value 30: Driver side air bag circuit short to ground. Lamp flash code: 22
1.51 DTC B2295 Error value 29: Driver side air bag circuit open circuit. Lamp flash code: 22
1.52 DTC B2295 Error value 28: Driver side air bag circuit low resistance on squib. Lamp flash code: 22
1.53 DTC B2295 Error value 27: Passenger side air bag circuit short to battery. Lamp flash code: 23
1.54 DTC B2295 Error value 26: Passenger side air bag circuit short to ground. Lamp flash code: 23
1.55 DTC B2295 Error value 25: Passenger side air bag circuit open circuit. Lamp flash code: 23
1.56 DTC B2295 Error value 24: Passenger side air bag circuit low resistance on squib. Lamp flash code: 23
1.57 DTC B2296 Error value 31: Driver side impact sensor communications fault. Lamp flash code: 43
1.58 DTC B2296 Error value 30: Driver side impact sensor internal fault. Lamp flash code: 43
1.59 DTC B2296 Error value 29: Passenger side impact sensor communications fault. Lamp flash code: 44
1.60 DTC B2296 Error value 28: Passenger side impact sensor internal fault. Lamp flash code: 44
1.61 DTC B2296 Error value 19: Crash sensor communications fault. Lamp flash code: 42
1.62 DTC B2296 Error value 18: Crash sensor internal fault. Lamp flash code: 42
1.63 DTC B2434: Driver safety belt buckle switch short circuit to ground. Lamp flash code: 51
1.64 DTC B2435: Driver safety belt buckle switch resistance out of range. Lamp flash code: 51
1.65 DTC B2438: Passenger safety belt buckle switch short circuit to ground. Lamp flash code: 52
1.66 DTC B2439: Passenger safety belt buckle switch resistance out of range. Lamp flash code: 52
1.67 DTC B2477: Air bag control module configuration failure. Lamp flash code: 54
1.68 DTC B2691: Driver safety belt buckle switch open circuit or short to battery. Lamp flash code: 51
1.69 DTC B2692: Passenger safety belt buckle switch open circuit short to battery. Lamp flash code: 52
1.70 DTC C1414: Incorrect Module Design Level. Lamp flash code: 15
1.71 DTC C1947: Seat position sensor short circuit to ground or battery. Lamp flash code: 49
1.72 DTC C1948: Seat position sensor resistance out of range. Lamp flash code: 49
1.73 DTC C1981: Seat position sensor open circuit. Lamp flash code: 49
1.74 Air bag control module disconnected or inoperative. Lamp flash code: continuous
Granworth
Namn: Kristian S
Dröm bil , se foto.
Medlemsnummer: 540
Re: airbag
Tjena.
kollade med honom idag och det blir så här ...
Tändning / tändlås i läge 2 , lampan lyser med fast sken .
Motorn startas och lampan släcks , förblir släckt i ca 20 sekunder och sen tänds den och lyser med fast sken , obs inget blinkande någonstans .
vi provade även med att koppla från batteriet helt ( över natten ) men det hjälpte inte .
Vi är tacksamma för all hjälp och förslag vi kan få ..
krille.
Nilsson97
Namn: Lundqvist Nilsson
Re: airbag
Inlägg av Nilsson97 »
Eftersom lampan inte blinkar kanske ni inte får fram någon felkod på det sättet. Har ni möjlighet att läsa av SRS-systemet med diagnosutrustning som fungerar på en Scorpio från -93?
Det är nog nästa steg innan ni börjar byta delar på chans. Jag skulle nog låta airbagkontakterna vara tills ni vet lite mer om vad felet beror på.
lgnystrom62
Namn: Anna Svensson
Kör: Volvo
Medlemsnummer: 1
Re: airbag
Inlägg av lgnystrom62 »
Nilsson97, det e typ enda rätta, utan avläsning gissar man bara.
