S: Cosworth parts...
Jasu
Namn: Jani Kataja
Kör: BMW
Inlägg av Jasu »
New / unused
-HKS GTII 60mm wastegate 700e
-Champion spark plugs QC59C-4p 50e
-Crankcase evac system (Allstar) 50e
-Setrab STD oil cooler SE-125 140e
-Roose Motorsport boost hose (blue) T3/T34 Turbo - RS500 cooler 80e
-2wd water pump (original) 80e
-Alternator drop bracket (drops 30mm) 30e
-oil cap (original, with thread) 10e
-4wd power steering pulley (original) 30e
-4wd water pump pulley (original) 35e
-retainers x16 (original) 30e
-springs, washers x16 (original) 35e
-2wd distributor cap & rotor 20e
-Group-N quadrant 20e
-ARP2000 bolts for std. rods (without lubricant) 50e
-2wd turbo heat shield (original) 300e
-GGR carbonfiber turbo heat shield 350e
-2wd style 4wd turbo bracket (needs parts of 2wd bracket) 100e
-mk1 rear light gaskets (original, Lucas) 70e
-2wd stainless steel water pipe (radiator bottom, GGR) 55e
-4wd 90º stainless steel bottom water radiator pipe (Auto Specialist) 40e
-mk1 Sierra & Escort Cosworth front indicators (original) 250e
-GGR timing belt and tensioner 65e
Used:
-Bailey water swirl pot 80e
-Bailey 3dr header tank 120e
-8 injector inlet manifold 150e
-RS500-style turbo damper (GGR) 120e
-Raceline RL5 7½ x17" ET35 700e
-Raceline RL7 8x17" ET33 750e
-2wd Bosch starter 80e
-aluminum power steering foot 50e
-MS (909) remote oil filter leg 150e
-2wd thermostat housing 40e
-4wd thermostat housing 70e
-4wd oil filter leg (turbo oil output, hose included) 100e
Some pics here.
Parts are in Finland.
I can send parts or bring to Kista.
Pris/utgångsbud: Se prislista
Plats/närmaste stad: Storå (Finland) / Kista
