S: a few Cosworth parts
Jasu
Namn: Jani Kataja
Kör: BMW
Inlägg av Jasu »
New parts / unused
- Setrab STD-SE-125 oil cooler 140€
- Group N quadrant ratchet 20€
- 90º water pipe under the radiator 4wd (AS) 40€
- RS500 Samco 76mm blue boost hoses + K&N filter with trumpet (hoses tested) 300€
- 4wd cam bearings (Burton) 25€
- LHD throttle cable (GGR) 45€
- 3dr remanufactured front indicators 70€
- 6151069 wiper stalk (newer model) 50€
- 6096586 3dr right front indicator 125€
- 6096588 3dr left front indicator 125€
- 6118290 Lucas MK1 rear light gaskets 60€
- 6136177 rear wiper arm 20€
- 1583744 2wd water pump pulley 100€
- 6460817 4wd water pump pulley 100€
- 1659225 4wd turbo heat shield foot 30€
- 6542403 2wd cambelt cover bolt 20€
- 6158072 aux pulley washer 20€
- 1492706 2wd clutch fork 50€
- 1656339 moonstone blue plastic sleeve body kit rivets x12 24€
- 6073718 rubber plugs x10 20€
- 6096616 3dr right side yellow fog light 150€
- 3dr bumper inside corner plastic brackets/clips 25€
- radiator fitting bolts 30€
- clutch and brake pedal rubbers 20€
The following are used:
- Bailey water swirl pot 80€
- Bailey power steering tank (new cap) 120€
- Bailey windscreen washer tank (with a new cap, pump and level sensor) 180€
- 4-spoke Motorsport steering wheel 120€
- Wolf Sierra Cosworth instrument panel (300 km/h - 10,000 rpm) 450€
Here some pictures.
The parts are in Finland.
Dispatch by mail.
The buyer pays the postage.
janikataja@msn.com or PM.
Pris/utgångsbud: Se prislista
Plats/närmaste stad: Isojoki
