Focus RS: Ford artikel/reservdelsnummer
Focus RS
Namn: Per-Anders G
Kör: Ford
Medlemsnummer: 3
Inlägg av Focus RS »
1134864 - 2 x front discs
1135058 - RS Caliper with pads o/s
1135059 - RS Caliper with pads n/s
6107891 - Copper washers brake parts
1040740 - 2 x banjo fittings
1144187 - 4 x bolts M12 X 35mm
1135173 - 2 x rear discs
6701988 - Grease cab rear hub
1135174 - Rear hub assembly complete
1135176 - Rear spindle o/s
1135177 - Rear spindle n/s
1213134 - RS Spindle adaptor
1141940 - Splash sheilds rear o/s
1141939 - Splash sheilds rear n/s
1148903 - Screws for rear splash guards x8 M12 X 22mm
1146926 - RS rubber insulator bracket assembly
7346525 - 2 x RS Hub’s
1135079 - RS Knuckle o/s
1214041 - RS Knuckle n/s
1143475 - 2 x RS Front Spring
1135069 - RS Shock o/s/f
1135104 - RS Shock n/s/f now 1205237
1143476 - 2 x RS Rear Spring now 1203608
1135070 - 2 x RS Rear Shock
1134072 - R/H RS Door Trim
1134073 - L/H RS Door Trim
1134074 - R/H ¼ RS Trim
1134076 - L/H ¼ RS Trim
1134728 - RS Seat Base Cover R/H
1134720 - RS Seat Base Cover L/H
1134717 - 2 x RS Foam Base
1134738 - RS Seat Back Cover R/H
1131423 - RS Seat Back Cover L/H
1134718 - 2 x RS Foam Base
1136176 - RS Steering Wheel
1139933 - RS Instrument Cluster
1237743 - S/S GearKnob
1219818 - Hand break lever (Complete)
???????? - Starter Button
1127181 - Centre Dash Panel around radio/heater (Black)
1135258 - Audio 6006E Security Panel
1142271 - Glovebox Light
1097542 - Ghia' Intermittent Wiper Stalk (not O.E)
4130504 - Ghia' Internal Lamp with Map Lights (not O.E)
1105527 - Audio Stalk
1117686 - Remote Control Keyfob
1132629 - Mirror Inner Cover (With switch hole) o/s
1132622 - Mirror Inner Cover n/s
6913144 - Electric Mirror Switch
1145484 - LH/RH Door Handles Primed
1202478 - Lock Bezels with no key hole primed
1203320 - Lock Bezels with key hole primed
1133961 - Electric Mirror o/s
1133966 - Electric Mirror n/s
1078771 - Mirror Cover (Primed) o/s
1078772 - Mirror Cover (Primed) n/s
1139649 - Rear bumper mounting bracket l/h
1139647 - Rear bumper mounting bracket r/h
1150343 - Rear towing eye cover
1218226 - R/H RS Headlamp
1218242 - L/H RS Headlamp
1204400 - RS Rear Bumper
1211879 - RS Front Bumper
1134222 - RS Grille
1216718 - R/H RS Wing
1216719 - L/H RS Wing
1211829 - RS Rear Spoiler
1149216 - RS Quarter Panel n/s
1149215 - RS Quarter Panel o/s
1211830 - RS Side Skirt
1211831 - RS Side Skirt
1134863 - RS Wheel 8 x 18
1307094 - RS Wheel Centre Caps
???????? - S/S Tyre Valve Caps
1089611 - 'Focus' Rear Tailgate Badge
1135344 - 'RS' Rear Tailgate Badge
1135343 - 2 x'RS' Side Pillar Badge
6999357 - Touch-Up Paint (Imperial Blue) now 1332784
1137928 - RS Clear Front Flasher Lamp
1137929 - RS Clear Front Flasher Lamp
1030007 - Bulb Holders for Front Flash Lamps
1148794 - RS Clear Side Repeater Kit
1230159 - Cat to turbo clamp on FMC part finder comes up heat sheild
1226549 - Fog Lamp LH
1226552 - Fog Lamp RH
1073568 - Rear windscreen sunblind
1073570 - Rear side window sunblinds
1073377 - Plastic boot liner
1142450 - Foot well mats
1222249 - Engine Heatsheild top front of rocker cover Chrome
1135064 - RS Steering Rack (exchange)
4327071 - RS power steering pump
1226625 - Outlet hose from turbo
1227883 - Amal Valve
1227855 - Solonoid to hose to actuator
1227864 - Solonoid hose to turbo
1227886 - Solonoid hose to exhaust
???????? - Boost hose intercooler to manifold
1136112 - RS Water Pump Housing
1207516 - RS Water Pump
1138298 - RS Water Pump pulley
1141582 - RS housing
1135481 - RS thermostat housing
1018219 - RS water pump bolt & washer assembly X3
1001993 - RS thermostat
1149766 - RS outlet water pump
1102051 - Heatsheld water pump
1217353 - RS inlet manifold
1149320 - Leather Gear shift Boot
1214006 - Gear Lever
1121854 - Reverse lift collar spring
1121945 - Reverse lift collar alloy
6820392 - Rubber washer gear lever base
1214008 - Gear shift pivot
1121944 - Actuator assembly gear shift
1123612 - Connector assembly gear shifter
1147007 - Bracket for gear shift cable assembly
6509353 - M10 hex nut
1205812 - Gear shift cable to gearbox 1 of 2 required
1126616 - Gear shift cable to gearbox 2 of 2 required
1068980 - Gear shift cable clip
1306260 - Floor carpet midnight
1121948 - Bush gear shift housing
1121943 - Gear shift housing assembly upper
1214011 - Transmission control selector
1214009 - Gear shift housing assembly lower
1146296 - Engine mount
1227880 - Throttle elbow
1227870 - Throttle elbow rubber gasket
4332280 - Throttle plate housing
1001599 - Potentiometer Focus RS
1144167 - Throttle gasket
1120437 - Accelerator bracket
1090949 - Inlet manifold Gasket x 4 reqd
1054013 - Gasket
1223957 - Inlet manifold bolt spacer x2 reqd
1228059 - Inlet manifold heat shield
1205688 - Support bracket
1079827 - Blanking cap Focus RS only!
7165249 - Gasket
1149611 - Bypass valve
1217355 - Bracket
1137631 - Fuel regulator
1203089 - Injection fuel rail
1053951 - Injector retaining clip x4 reqd
1136046 - Standard injectors x 4 reqd
1136222 - Heater hose outlet
1134560 - Connecting hose
1205551 - Hose assembly
1134140 - Brake hose front O/S
1137802 - Brake hose front N/S
1204444 - Hose overflow
1139240 - Radiator hose upper
1134583 - Radiator hose upper
1141724 - Radiator hose lower
1134578 - Rad hose to header tank
1150362 - Rad hose to header tank
1135352 - Air cleaner assembly
1232330 - Air filter
1138279 - Air duct to turbo intake
1227214 - Re-circ dump valve
3043533 - Air charge sensor
1227881 - Dumpvalve to inlet tube
1227884 - Dump valve to inlet manifold
1228018 - Blanking plate for MAF sensor
1227868 - Air box mounting bracket
1136109 - Turbocharger
1136111 - Exhaust Valve (inlets are standard zetec e items)
1217354 - Exhaust manifold
1035595 - O2 Sensor (blue)
1136214 - Cataytic convertor
1135084 - Cat to exhaust coupler
1053108 - Hego sensor (green)
1134864 - Brake discs x2
1037660 - Cam belt
1216075 - Camshaft pulleys
1107573 - Cam belt tensioner
1213852 - Cam belt idler pulley
1663875 - Cam belt guide
1135052 - Cam belt damper assembly
1216141 - Cam belt crankshaft gear
1230634 - Complete clutch kit less release bearing
7166796 - Release bearing
1214775 - Cylinder assembly
1137993 - Tailgate handle painted
4184381 - Door moulding primed O/S
4184382 - Door moulding primed N/S
1204377 - Rear qtr moulding painted O/S
1204380 - Rear qtr moulding painted N/S
1136724 - Anti roll bar bushes
4186514 - Anti roll bar
1135077 - Tie bar
1150984 - Drive shaft
1216710 - Cylinder head complete with valves
1105772 - Cylinder head gasket
1135346 - Engine block
1144165 - Turbo ceramic heatsheild
1207156 - Water pump kit
1150348 - Front strut bump stop
1141589 - Exhaust manifold heatsheild
1144132 - Camshaft cover (rocker cover RS)
1126120 - Camshaft cover (rocker cover RS) Gasket
1053902 - Head to exhaust manifold gasket
1227210 - Alarm fob £42.34+vat
1230737 - Brake hose protector under front wings stops rubbing paint
1226543 - Starter Switch
5051325 - Tyre Valve
1024339 - Exhaust manifold studs “x7”
1224370 - Long stud “x1”
6518102 - Nuts for exhaust manifold (x8)
1227588 - Manifold to turbo bolts (x4)
4555047 - Latch Assembly Hood
1053902 - Manifold to head gasket
1208444 - Manifold to turbo gasket
1003736 - Manifold to head spacers (pack of 5)
1227588 - Turbo bolts (hex) (pack of 4)
1227190 - RH Bezel; (£25.12) fog lamp cover
1227198 - LH Bezel; (£13.52) fog lamp cover
1074368 - Tailgate gas struts 3/5 door changed to 1150277 apparently
1212516 - Water pipe under O/S/F wheel arch from oil cooler to top of rad
1214775 - Clutch master cylinder/clutch release bearing
1065148 - Drive shaft oil seal same each side
1000530 - Wheel arch protector push clips
6998849 - Under tray push clips x 4
4138872 - MAF sensor Focus RS
1007932 - Front bumper clips that hold the under tray on
1146716 - Water hose that feeds turbo Part Number 1M5O 8A567-AA
1128983 - Scuttle panel tape/sealant
1202935 - OE Spark Plugs
1382861 - Odour Filter
1465018 - Fuel Filter
1119421 - Oil Filter
1146299 - Front top mounts
