ST170: Ford artikel/reservdelsnummer
- Namn: Per-Anders G
- Kör: Ford
- Medlemsnummer: 3
4573474 - Accelerator cable
6793327 - Clips for the Accelerator cable (above)
4708066 - CAT heatshield
1212560 - Air deflector
1007932 - Plastic Scrivets for the air deflector (above)
4359190 - Snorkel
4337133 - Manifold
4501548 - Exhaust Manifold Heatshield
4589460 - Cat (including gaskets)
1663888 - Bolts for the Exhaust Manifold Heatshield (above)
4346328 - Dipstick tube
1335994 - Power Steering pipe
1150712 - Door switch with the striker
1029454 - Centre Cap Removal Tool
4447983 - Engine Air Shut Off Control (IMRC actuator)
1120425 - Rear, top brake light
4616972 - Right headlamp
4616975 - Left headlamp
4411010 - Upper grille including badge assy
1211518 - Lower Bumper Grille
1144014 - Splitter for the front bumper
1132682 - Front "Ford" Badge
1024755 - Badge spring
1125799 - Retaining clip
4411010 - Grille including the badge
4328409 - Rear Tailgate Badge
1211972 - Primed surround
1430131 - Bonnet - unprimed & unsprayed
1434059 - Rear Wiper arm
1404802 - Rear Wiper blade
1364038 - Ford Aero Blades
1139410 - RH Washer Jet Cover
1139411 - LH Washer Jet Cover
4707408 - Clutch
4358475 - Slave cylinder
1310280 - Flywheel
1133522 - Master Cylinder
1142600 - Flywheel bolts (needs 6)
1348627 - 6 speed gearbox
4524181 - Clutch plate
4328189 - Clutch & brake pedal ext
4411312 - Rear brake disc
1425407 - Rear brake pads (Economy)
4410264 - Front brake disc
5029238 - Front brake caliper spring
4346371 - Front Brake Pads
1359884 - Front Brakes Pads (Economy)
1250435 - Oil Pressure & Temperate gauges
1333348 - Surround for Oil Pressure & Temperate gauges (above)
4346372 - RH caliper (Front)
4346373 - LH caliper (Front)
1075553 - RH caliper (Rear)
1075554 - LH caliper (Rear)
1112547 - Front wheel bearing
1212546 - Rear wheel bearing
3903036 - Front Hub Assembly
4356606 - RH Side Front Knuckle
4356607 - LH Side Front Knuckle
4176459 - Brake Sheild Left
4176460 - Brake Sheild Right
1029131 - Rivets For Splash Shields (above)
4346382 - Brake Caliper's Bracket x 2
1306212 - Handbrake Cable
1053902 - Manifold to Head Gasket
1003736 - Plastic guild for manifold
4361730 - Exhaust Manifold to CAT Gasket
1094552 - Oil emissions controler gasket
4344549 - Cat to flexy Gasket
4431556 - Center exhaust
4590143 - Exhaust Flexipipe
4431557 - Rear exhaust
3559458 - Up Stream Lamba Sensor
3721930 - Down Stream Lamba Sensor
1066071 - Oil filter
1072246 - Panel Air Filter
1224577 - Fuel Filter
1382861 - Pollen Filter
1316193 - Pollen Filter Seal
1343795 - Oil 5W/30 5 litres
3964918 - Petrol filter
1139873 - Steering wheel
4328003 - Accelerator Pedal
1150277 - Rear Boot Lifter
4449172 - Leather Handbrake lever set
1308229 - Ford Gear Lever Knob (6 Speed)
4331240 - Gear Knob (6 speed with leather)
1211548 - Left & Right fog light bezel (silver)
4346353 - RH Fog Lamp
4346356 - LH Fog Lamp
1211506 - RH Fog Lamp surround/bezel
1211505 - LH Fog Lamp surround/bezel
1302615 - Adaptor Wire (If Converting To Fogs)
1114243 - Rear Spoiler (primed)
1302615 - x 2 adaptor wire (from standard to ST fog lamps)
1143343 - Throttle body
1317972 - Coil pack
1092379 - No 1 HT lead
1114743 - No 2 HT lead
1114744 - No 3 HT lead
1114745 - No 4 HT lead
1151999 - Spark Plug (each)
1149555 - Air Box
1072649 - Instrument cluster surround
1202121 - Instrument cluster (with esp)
1138852 - Instrument cluster (without esp)
1322385 - Meteor Grey radio surround
4172365 - Silver internal door handle x2 Right
4172366 - Silver internal door handle x2 Left
1131256 - Heater dials
1139773 - Oil pressure & temp gauge
1303347 - Handbrake Gaiter
4395784 - Gearbox Gaiter
1071744 - Head gasket
4412072 - "DURATEC ST" engine badge 1211887 - Camshaft Cover with bolts
4448217 - Coil Pack Cover
1073096 - Tensioner belt
1222181 - Rocker cover gasket
1371760 - Rocker cover
4404004 - Alternator belt
1037600 - Timing Belt
1339025 - Fuel Pump
1228096 - ECU
4172365 - Silver internal door handle Right
4172366 - Silver internal door handle Left
1197638 - Interior light including the ultra sonic alarm sensor (CAT1 alarm)
4417789 - Rear shocker
1335994 - Power steering pipe
6742740 - Bits to go with the power steering pipe
1135388 - Front Mudflaps 3 & 4 & 5 doors & Estate
1073589 - Rear Mudflaps 3 & 5 doors
5016703 - Mud flap clamp
4327852 - Front springs
4335231 - Rear springs
4417814 - Left front strut
4327859 - Right front strut
4327867 - Rear strut
4464676 - Alloy
4424318 - Center caps
1135077 - Front anti rollbar drop link's x2
1145733 - Handle Assy tailgate (Primed only)
1150349 - Nut rear x2
1150358 - Bush spacer rear x2
1150355 - Bolt rear x2
1150991 - Plug with the seal (for coolant of the thermostat housing)
1132349 - The clip for above
1459574 - Exhaust Flexi
4172365 - Silver Internal door handle RH
4172366 - Silver Internal door handle LH
1347090 - Driver side front wing (not painted)
6483616 - Spare wheel clamp/rod
4359190 - Snorkel
4337133 - Manifold
4707408 - Clutch
1310280 - Flywheel
1317972 - Coil pack
1149555 - Air Box
1339025 - Fuel Pump
1228096 - ECU
4464676 - Alloy
