Säkringsschema till Focus Mk2 (2005-2006)
FAQ
Namn: FAQ
Kör: Allt
Inlägg av FAQ »
Säkringsschema för säkringsdosa i kupén till tidiga Ford Focus Mk2.
F37 - (10A) LH headlamp
F38 - (10A) RH headlamp
F39 - (20A) Cigarette lighter
F40 - (20A) Sunroof
F41 - (20A) Door function control module, passenger
F42 - (7,5A) Electric door mirrors
F43 - (10A) Fuel additive control module, heater function control module, keyless entry control module, steering column adjustment module
F44 - (10A) Data link connector (DLC)
F45 - (10A) Ignition switch, light switch
F46 - (10A) Instrument panel
F47 - (15A) Windscreen washer jet heaters
F48 - (20A) Daytime running lamps
F49 - (15A) Light switch
F50 - (20A) Windscreen wipers – low speed
F51 - (15A) Fuel pump (FP) relay
F52 - (25A) Heated rear window
F53 - (7,5A) LH tail lamp, LH headlamp
F54 - (7,5A) RH tail lamp, RH headlamp
F55 - (20A) Door function control module, driver
F56 - (20A) Keyless entry control module
F57 - (10A) Door mirror retract control module, alarm system horn
F58 - (15A) Alarm system, navigation system, touch screen display
F59 - (20A) Trailer control module
F60 - (15A) RH headlamp
F61 - (15A) LH headlamp
F62 - (20A) Electric seats
F63 - (25A) Electric door mirrors, electric windows
F64 - Not used
F65 - (10A) Supplementary restraint system (SRS)
F66 - (7,5A) Gas discharge headlamp control module, light switch
F67 - (10A) Alarm system, instrument panel
F68 - (7,5A) Alarm system, audio system, instrument panel, navigation system
F69 - (20A) Light switch
F70 - (10A) Fuel additive control module, hazard warning lamps, heated rear window, heated seats, heated windscreen, heater function control module, parking aid control module, sunroof, windscreen wiper rain sensor
F71 - (10A) Light switch
F72 - (25A) Multifunction control module
F73 - (7,5A) Licence plate lamps
F74 - (15A) Stop lamps
F75 - (10A) Engine management, accelerator pedal position (APP) sensor, transmission control module (TCM)
F76 - (7,5A) Parking brake control module
F77 - (25A) Central locking
F78 - (15A) Rear screen wash/wipe system
F79 - (15A) Auxiliary power socket
F80 - (10A) Battery saver relay
F81 - (20A) Door function control module, right rear
F82 - (20A) Door function control module, left rear
F83 - (10A) Audio system – rear
F84 - (10A) Electric windows, reversing lamps
F85 - Not used
F86 - (20A) Heated seats
