Fiesta st tråden
Kör: Ka -97, Transit -98 & 01, Kuga -12, Taunus -66, Fiesta -77, Granada -84, Escort -84
Re: Fiesta st tråden
Inläggav RickardEM » tor mar 26, 2020 11:04 am
CAR Magazine provkör Ford Fiesta ST. :)
Verkar vara en specialversion, Performance Edition.
Ford Fiesta ST Performance Edition
Flow Formed Alloy Wheels
The 10-spoke, 18-inch flow formed alloy wheels are lighter, stronger and more durable than a traditional cast wheel. Flow forming involves the application of pressure to the inner barrel of the wheel while spinning and after it has been cast, which stretches and compresses the aluminium, increasing tensile strength. These alloy wheels are finished with a winter-resistant, high-grade triple layer "Magnetite" paintwork.
Fine tune your driving experience
Performance coilover suspension pack with stainless steel damper housing and powder-coated Ford Performance Blue springs lowers the ride height by 10mm at the front and 15mm at the rear, and has been extensively tested at the Nürburgring Nordschleife by Ford Performance engineers. The suspension can be adjusted manually, with 12 bump settings and 16 rebound settings for a personalised, finely-tuned driving setup.
ford-fiesta_st-uk-interior1-16x9-2160x1215-central-display.renditions.extra-large.jpg
ford-fiesta-gtb039202-21x9-2160x1215-ford-fiesta-st-performance-parked-near-sea-back-view.jpg
ford-fiesta-gtb039202-21x9-2160x1215-ford-fiesta-st-performance-parked-near-sea-front-view.jpg
ford-fiesta-gtb039202-21x9-2160x1215-ford-fiesta-st-performance-parked-near-sea-grill.jpg
FORD CLUB SWEDEN – Ordförande
kenkaniff
Namn: David Buhr
Kör: Fiesta st -16 mountune Escort cab -90 Mondeo -12
Medlemsnummer: 498
Inläggav kenkaniff » fre mar 27, 2020 7:19 am
Zafiro skrev:Då har man trimmat sin bil. Första gången man gör en sån sak :)
Vad blev det för kul då??
Zafiro
Namn: Andreas K
Kör: Ford Fiesta ST MK8
Inläggav Zafiro » fre apr 03, 2020 9:16 am
Köpte från Dreamscience
https://www.dreamscience-automotive.co. ... m-imap-e6/
Tur man beställde i tid. I england har man stängt ner pga Corona. Man kan fortfarande beställa men inget skickas förrän deras regering tillåter.
zowix
Namn: Björn B
Kör: Fiesta ST+ -15
Medlemsnummer: 321
Inläggav zowix » sön apr 05, 2020 1:53 pm
Upptäckte igår när jag tog bort plastkåpan på motorn att den har skavt ner en sladd så att kopparn syns... :(
Tänkte med detta inlägg uppmärksamma andra ägare av ST mk 7 och kontrollera så att det inte har hänt er också.
Bifogar bild.
Kåpa på, har linda runt kabeln med eltejp.
Utan kåpa, syns lite naken koppartråd där.
FORD CLUB SWEDEN – Ledamot.
Fiesta ST 2015 :prop:
http://www.garaget.org/?car=376787
PB67
Namn: Pär B
Kör: Fiesta ST 2020
Inläggav PB67 » tis apr 07, 2020 4:46 am
Blev du nöjd? Känner du stor skillnad? Ge oss en liten review. :)
Zafiro
Namn: Andreas K
Inläggav Zafiro » tis apr 07, 2020 11:31 am
Det ingår tre olika mappningar, Ultima, Ultima+ och Ultima2.
Ultima+ har mer vrid i mellanregistret än Ultima2. Ultima2 har jämnare effekt kurva känns det som.
Just nu anväder jag mig av + varianten, den drar på som fan från typ 2500 prm till 4500 rpm, mellanregistret är en jävla skillnad mot original.
Visst är det skillnad mot original. Acceleration genom växlarna betydligt snabbare, räcker med att kolla pekaren på hastighetsmätaren så fattar man. Segdragning i 5 och 6 växel på motorväg också skillnad. Endast varit uppe i 160km/h men jävlar vad det går snabbt upp där.
Har inte dragit den fullt i ettans växel än, får känslan att däcken tappar grepp då. Bilen låter högre också, även i normal läget tack vare mappningen.
Har även köpt till ett K/N filter.
PB67
Namn: Pär B
Kör: Fiesta ST 2020
Inläggav PB67 » tis apr 07, 2020 12:17 pm
Tack! Det kliar lite i fingrarna men det känns jobbigt att börja ändra på en ny bil...
Zafiro
Namn: Andreas K
Inläggav Zafiro » tis apr 07, 2020 12:31 pm
PB67 skrev:
Jag väntade till min bil rullat 1600 mil. ViIle se så originalmotorn höll och inte strula. Sen vågade jag :)
Zafiro
Namn: Andreas K
Inläggav Zafiro » tor apr 09, 2020 6:08 am
Testade ett nytt videoprogram. Så skapade en kort film på eländet :)
Tokkugawa
Namn: Tony Magnusson
Kör: Mk8 Fiesta ST
Medlemsnummer: 503
Inläggav Tokkugawa » fre apr 17, 2020 6:54 pm
Snyggt! Har läst en del på engelska fiesta ST forumet och några som gillar dreamscience's Tune.
I höstas så installerade jag Collins Performance på min - precis som du sa så är det stor skillnad på mellanregistret. Det är till stor del pga. Ford begränsade vridmomentet elektroniskt i mellansegment, fast med trimmet då så plockas den spärren bort!
Jag gissar på att det var att man spinner som en galning om man tar i nu :D Och ford själva ville inte att man skulle göra det (lika mycket)
Personligen känner jag att det är väl upp till föraren att reglera sin högerfot. Får du någon ljudskillnad med din KN?
Samtidigt som jag la in en tune la till ett öppet filter, det vooshar rätt mycket mer.
PB67
Namn: Pär B
Kör: Fiesta ST 2020
Inläggav PB67 » fre apr 17, 2020 8:35 pm
Letar efter en bra butik att köpa K/N-filter (och deras filterolja) till min MK8. Nån som har tips?
Viss förvirring råder också med årsmodellerna i butiker märker jag. Om nån har modell-numret på just det filter jag behöver så vore det en bonus.
Tokkugawa
Kör: Mk8 Fiesta ST
Medlemsnummer: 503
Inläggav Tokkugawa » sön apr 19, 2020 4:23 pm
PB67 skrev:Letar efter en bra butik att köpa K/N-filter (och deras filterolja) till min MK8. Nån som har tips?
Den här borde passa :
svårt att säga 100, men enligt amazon "car fit" eller vad det nu är ska det passa en mk8, det står 2017-2020. Kan vara samma airbox som det var till mk7 också. Sen Olja är det väl bara att ta ifrån Amazon också.
Zafiro
Namn: Andreas K
Inläggav Zafiro » tor apr 23, 2020 6:13 am
Tokkugawa skrev:Snyggt! Har läst en del på engelska fiesta ST forumet och några som gillar dreamscience's Tune.
Vet inte om det har med KN att göra eller DS mappning men visst låter den högre både standard och i sportläget. Även på tomgång.
Beställde mitt KN genom mountune. Perfekt passning. Tyvärr inte lådan kvar så jag kan inte se numret på filtret.
https://www.mountunestore.com/collectio ... air-filter
Zafiro
Namn: Andreas K
Inläggav Zafiro » fre apr 24, 2020 6:47 am
Här är en video med ljud. Så låter min :)
PB67
Namn: Pär B
Kör: Fiesta ST 2020
Inläggav PB67 » lör maj 09, 2020 8:21 pm
Zafiro skrev:Jag väntade till min bil rullat 1600 mil. ViIle se så originalmotorn höll och inte strula. Sen vågade jag :)
Jag slog till och har testat ett par dagar nu... Jisses vilket vridmoment :crazy:
